FS-6525MFP energy light on
Re: FS-6525MFP energy light on
Hard to say how likely it is, but I would definitely try plugging the device into another circuit in the building. I know I live in an area with extremely dirty power and can cause all sorts of confusing power state inconsistencies. Although to be honest this is based more on my experience with PCs than with MFPs, so take it with a grain of salt. Certainly couldn't hurt to try. -
the big filter capacitors in the low voltage pwb are toast. there was a firmware update that kept waking the machine for a second in order to prevent those caps from overcharging from recified input noise while no load. you'll need to replace the low voltage pwb which is beside the LSU in the center of the chassis. on a problem machine that eats boards, might be tempted to add some 1meg resistors across those two caps to bleed off the overcharge.
watch out for those caps when handling these boards from cadavers, they keep a charge and will blow the tip right off a screwdriver that might find it's way across the points!Comment
