C0950 error code?
  • copiertec
    • Jan 2016
    • 2207
    C0950 error code?
    I have a TA-5501i with a PF-740, DP-772, and a DF-770. I noticed in the error log it had several C0950 error codes, I looked it up in the service manual but could not find that error in the service manual. What is the C0950 error related to?
  • pascalb.
    • Aug 2016
    • 47
    Re: C0950 error code?
    Hello,
    do you have a FAX?
    this is what I found
    "C0950: FAX job stay error
    Print processing of the received FAX could not be executed and the job continues staying."
    have a good day
    Do not lament,
    do not mock,
    do not hate,
    but understand.
    • copiertec
      • Jan 2016
      • 2207
      Originally posted by pascalb.
      Hello,
      do you have a FAX?
      have a good day
      Thank you, pascalb, yes it does have a fax. I will have to look in the fax manual and possibly make fax adjustments.
      • pascalb.
        • Aug 2016
        • 47
        Hello
        You have to make the latest Firmware.
        I had a technical bulletin which spoke about this problem.
        good luck
        Do not lament,
        do not mock,
        do not hate,
        but understand.
        • copiertec
          • Jan 2016
          • 2207
          Hello
          good luck
          Thank you, pascalb, I just updated it when I was there to 7.05, maybe that will resolve the issue.
