The power button on the keypad is unresponsive when the operator tries to power up the copier. This happens only in the morning. The button works fine when the machine is in sleep mode. When they turn the machine off and back on, it works fine. I have checked the connections on the operation panel and I have updated the firmware. Has anyone else seen this problem?
TA-6551ci issues with power button on keypad
Re: TA-6551ci issues with power button on keypad
The power button on the keypad is unresponsive when the operator tries to power up the copier. This happens only in the morning. The button works fine when the machine is in sleep mode. When they turn the machine off and back on, it works fine. I have checked the connections on the operation panel and I have updated the firmware. Has anyone else seen this problem?Comment
