ok, i have 3 TA kicking our butts.
#1Tray 3 is mainly showing jam 0533 codes
Tray 4 has multiple jam codes : 0534, 2604, 2613, 2614
we have replaced the pwb, the main drive assy. Clutch on vertical feed. Updated firmware and rollers to the tray 3.
We have swapped out the tray 3 feed assy, the vertical feed assy and the bridge unit from another 7052ci
We have toned out the connectors from the sensors to the pwb and all ring good.
#2 and #3 both giving c6770 codes. paper folding up inside fuser. we have changed fusers multiple times. have widened the lead margin as well. the #2 machine is also giving off f186 codes. we clear the paper and the machine runs for awhile. tech support thinks the 6770 is the power source. trying to get power monitor to test. all firmware up to date.
any suggestions on my problem children?
