Copystar cs3035
  • copysys
    • Aug 2008
    • 41
    Copystar cs3035
    i will be installing a 400k pm kit on the cs3035, which is drum unit ,developer unit, fuser unit and transfer charge unit replacement.
    Is there a simulation/calibration when replacing the drum and developer unit for this mach? If so, please assist. Thanks in advance
  • aragul
    • Dec 2007
    • 128
    U130 initializes the developer unit and clears the dev count
    U251 clears the maintenance message
    U110 and U111 should clear on their own (drum counts).
    Don't forget to clean the 2 filters on the bypass side (1 is behind the cover) and get rid of the paper dust around the developer unit and that red felt cleaner.
    • copysys
      • Aug 2008
      • 41
      That did it! Thanks for all your help
      • 10871087
        • Jan 2005
        • 1062
        What if every model had a PM this easy?
        • Quaz
          You have to run a toner add sim. I believe it is sim 131. Don't hold me to it. Print out the management list and it will tell you. sim # 000
