Big Problem on TASKalfa 2552ci - Panel
  • kyove
    • Apr 2015
    • 62
    Hi Guys,
    I've just retired a TASKalfa 2552ci from a customer.
    Panel looks like in image attached.
    I don't think can be a panel problem. I try to set TA to copy mode and press start to make a copy.
    Original sheet is scanned thru DP but printer stay with Process and Memory blinking.
    Maybe the main board?
    What do you think?
    I don't know what can be happened to this machine, client called me to repair it.
    Thank you in advance,
    Kyove
    • 2621
    Re: Big Problem on TASKalfa 2552ci - Panel
    Since you say it tries to copy and then hangs up I would look at the main board first.
      Originally posted by kyove
      Hi Guys,
      What do you think?
      Kyove
      The possibilities are:
      - LCD panel
      -Cable that runs from Main PCB to LCD panel
      - Main PWB
      I'd start with the least expensive stuff before replacing Main PWB as it will be expensive.
      EDIT: You may try calling Hytec and talking to their service dept. as they have extensive knowledge in troubleshooting board problems. They've helped me in the past. See link below:
      Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
      • craigster
        • Apr 2016
        • 201
        So I had one do that on a TA4551ci panel did the same thing, problem was the fan on the cpu was not working properly, basically cpu was over heating. replaced fan and all good.
          If his problem was an over-heating situation, I would think he could turn the machine off to let it cool off and it would work for a while until it over-heated again.
          • diedux
            • Jan 2017
            • 124
            Seen this on brand new 2552ci machine (after 2224 pages). Faulty MB.
            BR.
            • toddanderson
              • Dec 2005
              • 231
              try the memory dim on the main pwb
              • kyove
                • Apr 2015
                • 62
                In my case I don't think could be an over heating.
                Yesterday I shut down the machine and disconnect power cord. This morning I have the same problem.
                I'll change the main board and post future developments.
                Thank you all,
                Kyove
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Hi Guys,
                  What do you think?
                  Kyove
                  I would think its more likely to be control panel but I've never had my self. Good luck
                  Regards Mark
                  • kyove
                    • Apr 2015
                    • 62
                    Hi Guys,
                    Replaced
                    302L794093 - PARTS PWB MAIN ASSY EU SP - Main PWB on Service Manual
                    Problem SOLVED!!!!
                    Thank you all, you are good guys!
                    Kyove
                    • Femzytech14
                      Re: Big Problem on TASKalfa 2550ci - priter board
                      Hi All
                      I have a Taskafa 2550ci having issue of not booting and always the coping lamp is on and i lean from forum that it's a problem from printer board.
                      Pls can anyone tell me if the printer board can be repair or i need to change it before the machine can start working back
                        Originally posted by Femzytech14
                        Hi All
                        You can get a replacement board repaired at Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
                          Hi All
                          before swapping any boards out...
                          have you tried a firmware replacement?
                          what have you tried to fix the problem?
                          just because one person had a board that fixed it doesn't mean that'll be the fix for your issue
                          boards are expensive your time is cheap .. do your proper troubleshooting.
