Kyocera scan with FTP using SSL/TLS
+ More Options
Posts
  • bon-go
    • Oct 2020
    • 6
    Hello,
    on some MFP i'm unable to define a working address book entry which scans via encrypted FTP. It's working on newer MFP like Taskalfa 3353ci with the 'new' webinterface but it's not working on Taskalfa 4052ci or M5526cdn or M6526cdn with the 'old' webinterface. FTP without encryption works there as usual but FTP using SSL/TLS does'nt as Kyocera describes (network protocol encrypted FTP, network security enable SSL and TLS in different versions and so on).
    On the newer webinterface address book configuration is a separate test button which offers encrypted connect test and this is working with FTP over TLS. In the older webinterface there is no such button. It does'nt matter what I try: it will not connect with TLS or SSL. I tried with different ports, protocol, destinations, ftp server (Filezilla FTP Server, vsFTPD, pure-ftpd), whatever i do: packet capture shows no initial TLS or SSL handshake on the older MFP.
    Does anyone have a working solution to scan with FTP using SSL/TLS on Kyocera Taskalfa or MFP?
