Ta 3552 ci C0800, J0100
  • Donnie
    • Aug 2011
    • 79
    Codes are happening in copy mode, customer will clear Jam in case of j0100, or pwr on/off for C0800. Firmware is up to date, fuser has been replaced per webinar specifically pertaining to these issues. Happens at least once a day. Any help would be appreciated. Thanks.
  • kuby
    • Oct 2007
    • 1413
    Re: Ta 3552 ci C0800, J0100
    I would start by re-flashing the firmware with the current firmware and not the Turbo mode firmware. The manual says the image data if faulty. Then check the PF rollers for each cassette. Reconnect the connectors on the main PWB. Then, fix or replace the wires if they are pinched by the other part or if they have any damage. When the issue is not resolved, replace the main PWB.
    • Donnie
      • Aug 2011
      • 79
      Thanks for the reply. Turns out this is an issue our rep. has seen before. There is a q/a pertaining to dp grounding. So far the machine has been working. I will update post next week after customer has been using it longer. Thanks again.
      • Donnie
        • Aug 2011
        • 79
        This has taken care of the problem. Thanks.
        • toddanderson
          • Dec 2005
          • 238
          what was the Qa number that fixed it ?
          • Donnie
            • Aug 2011
            • 79
            2ND-0131. Thanks.
