KM-4850W error code C5110
  • bryanstu
    • 14
    I have a 4850 throwing C5110 errors. Changed the transfer unit, still popping the errors. Can a person screw with the pots on the HV pwb (turn down the voltages), or is the HV board itself thats maybe leaking. Only have one of these out, so working a little in the dark.
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    First you need to check the screws that hold in the Transfer HV pcb to make sure they are tight. A loose connection will give you that code. On the outside chance you may need to replace the Transfer HV PCB.
    My mission here on Earth is to help all you Dum-Dums!
    • bryanstu
      • 14
      Sounds simple enough. Will give it a closer look and post. Thanks for the heads up.
      • Yaman mozaik
        I have the same problem
        Printing faded black appears gray
        There was a spark between the DRAM and between the shipper bottom
        Been changed shipper bottom and nothing has changed
        I expect that there is a problem in high-voltage plate
        Please note that the code c5110 does not appear any plans always
        Only when I print Density photo need to be a large amount of high voltage
        • Yaman mozaik
          I think that the problem in the high voltage plate, but I can not experiment because it was the availability of a painting in my possession
