TA 3252CI
  • MLKIM
    • Aug 2025
    [Error Code] TA 3252CI
    Error code c7304 frequent occurrence and then black toner not adding automatically unless you add manually by simulation U131
  • sparkycivic
    • Apr 2017
    • 348
    Re: TA 3252CI
    that code means the motor which drives the yellow toner container isn't rotating. is the toner Kyocera genuine? is there any foreign objects in the mechanism of the container or the hopper?
