Kyocera fs 4200, the same model like ricoh sp 5300 blank print
  • Boki1990
    • May 2020
    • 1
    [Misc] Kyocera fs 4200, the same model like ricoh sp 5300 blank print
    Can someone tell me, on what part should i make attention
    I have change all the things that i thought should make those problem
    I have tried with changing
    -pcu ( like catridge for this model)
    -Charge and trans roles
    Even changed board of high voltage...
    Any idea?
  • patrickjlc
    • Feb 2015
    • 223
    Re: Kyocera fs 4200, the same model like ricoh sp 5300 blank print
    Did you check the plastic barrier in front of drum? If you remove the top cover there us a plastic barrier in front of drum.
    If it doesn't move or is on the wring pisition it will make the printer do completely white prints.
    Sent from my motorola one 5G UW using Tapatalk
