Kyocera M3645 Fax Issue
  • copyguy69
    • Feb 2016
    • 94
    I have a machine in a bank that will receive faxes fine. It appears to send a fax fine, but the page is blank on the other end to every number dialed. It appears that it went through fine. Is there a common issue like this that anyone is aware of? Any suggestions are welcome. Thanks in advance
    copyguy69
    • 30091
    Re: Kyocera M3645 Fax Issue
    only if customer puts the fax in the wrong direction
    • Santander
      • May 2009
      • 768
      copyguy69
      Is the customer putting the originals in the ADF face up? If the unit is sending the pages fine, it is most likely that they are inserting the originals so the back side is scanned which is blank.
      • JR2ALTA
        • Feb 2010
        • 2033
        With all the digital and VOIP issues I would throw it in my car and test it offsite.
        • kuby
          • Oct 2007
          • 1396
          You could always test it by putting double sided pages in the document feeder and try faxing. That way you would know if it was inserted the wrong way.
          • copyguy69
            • Feb 2016
            • 94
            Thanks for the replies. The original is correct and I had the customer send me a fax with print on both sides to make sure it was not put in incorrectly. Going to update firmware and try initializing the fax.
            copyguy69
              • 30091
              copyguy69
              Does it make a copy?
