TASKalfa 5053ci Toner showing up in cassette 1
  • EDSNOW
    • 187
    [Misc] TASKalfa 5053ci Toner showing up in cassette 1
    Hello Folks
    Seasons Greetings
    I had to look at a 5053ci today that is about 2 years old and life count of 430K.
    I noted toner had fallen into the cassette 1 (upper).
    I checked the area directly above the cassette inside the machine (in this case toner had dropped in the front)
    I saw that above the cassette there is a wire mesh material that when I touched some toner continued to fall. Not sure if this is part of any major component.
    I cleaned the area and inspected the developer/drum area, transfer belt looked ok as well.
    This is a new one on me as from what I understand cleaning of waste toner and duct work is in the back of the machine.
    Any thoughts greatly appreciated or if someone has had a similar issue I would like to know.
    Regards
    Ed
    Esnow@northwestel.net.
    • 900
    Re: TASKalfa 5053ci Toner showing up in cassette 1
    We have found it is a leaking Dev. unit. If you take the dev. unit and shake it the powder will start falling from the edges.
    • EDSNOW
      • 187
      Appreciate the response. Will check out.
      Thank You
      Ed
      • EDSNOW
        • 187
        Follow Up
        Inspected the developer unit and it is OK.
        Previous visit reseated drum / developer units as well as transfer belt unit.
        That being said several thousand copies had been made without any toner dumping.
        If something else comes up I will advise.
        Thanks to all who took the time to view the post.
