FS-3900DN Call Service 7000:0333721
  • parsia
    Hi,
    I have a Kyocera FS-3900DN printer that intermittently displays:
    Turning the printer off and restarting has cleared the message but I would like to know what causes it.
    I have been unable to find this code and am hoping someone could point me in the right direction.
  • Copier
    • Jan 2007
    • 27
    Toner motor lock error
    A motor over-current signal is detected
    continuously for 5 seconds since the
    toner motor is activated.
    • techman
      • Dec 2007
      • 49
      I have had this problem before check the toner cartridge and make sure it is snapped in all the way or cheack the gears if it is not set in right it can cause those gears to break or the teeth on the developer to wear out
