IB-51 Firmware Update
  • yurisan
    • Dec 2007
    • 109
    Anybody know how to update the firmware of a IB-51 wireless card? I am working with a M6535cidn that needs this NIC to be ver. 2.3.0 in order to support SSL/TLS ver 1.2 Downloaded the firmware, but when presented along w/ the rest of a firmware update via a USB drive, it does NOT get updated, nor is it listed on-screen. Doesn't get recognized in USB when only the IB-51 firmware file is present. Also, no success using U025 in service mode ("Very High" needs to be selected in the Security Level settings under the System Menu, according to service manual to get this function to work).
  • kuby
    • Oct 2007
    • 1371
    Re: IB-51 Firmware Update
    Try this..
    Turn machine off and insert wireless card. And turn the machine ON and wait of it to cycle. Then turn the machine OFF and insert the USB flash drive with the files copied to the root directory. (The way I do it is Unzip the file and then copy the contents of the folder it makes to the root directory of the flash drive). Turn machine ON and wait and see if it upgrades. Turn machine OFF and unplug the flash drive.
    • yurisan
      • Dec 2007
      • 109
      Originally posted by kuby
      Try this..
      It updates the regular firmware OK using this normal method as you described (power off, insert USB drive, power back on), but the wireless card does NOT get updated - tried by adding the IB-51 file to the other files for the latest firmware update in the root directory of the USB drive & performing the update, and also with ONLY the IB-51 file, in which case nothing happens and the machine just boots up normally and no update firmware screen is displayed. Either way, no luck.
      • kuby
        • Oct 2007
        • 1371
        Have you tried Kyocera Tech Support about the problem? And does the IB-51 show up as installed on the machine? And Firmware version is installed on the machine it self, 03/20 is the latest. The download site shows IB-51 firmware 2.2.6 (Maybe try that)
        • dschultz31
          • Aug 2018
          • 34
          see this thread:
          Kyocera IB-51 setup software
          • JR2ALTA
            • Feb 2010
            • 2028
            I had to get it from hotline.
            • toddanderson
              • Dec 2005
              • 231
              The firmware is done with IBVERUP Utility,
              Its been years since I used it, I cant find it any more and I dont find it on the mykyocera site.
              if anyone has it hopefully they can post it somewhere so people can download it.
              • B0265
                • Jan 2007
                • 718
                The last version of the IBVERUP utility I have seen is v3.02 but this doesn't seem to work in W10.
                • invalid_pointer
                  • Jul 2023
                  • 4
                  I recently hit a wall because I wasn't able to configure e-mail notifications on newly bought printers after I installed said network cards.
                  Long story short, I managed to get the files from the manufacturer, whole package needed to update to v. 2.3.0.
                  I'd gladly share those but no matter what I do, I can't upload anything bigger than few hundred KBs using that custom attachment manager. Any help will be appreciated.
                  • soros26
                    • Dec 2024
                    • 2
                    Hello.
                    Where find update firmware for ib-51? Now 2.2.6 - is it stable or not stable? And how update?
                    • invalid_pointer
                      • Jul 2023
                      • 4
                      Here's 2.30 that you can safely upgrade to - firmware + upgrade tool.
                      The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
                      • soros26
                        • Dec 2024
                        • 2
                        its old firmware, but thank you for your help
                        • invalid_pointer
                          • Jul 2023
                          • 4
                          You mean there's something newer than this? I'm genuinely intrigued. True, I had gotten my hands on 2.3.0 one year ago, so it's not recent, but still - where did you find any info about newer firmware and what's it supposed to have/fix?
                          • kuby
                            • Oct 2007
                            • 1371
                            Looked on Kyocera's web site for that model and IB-51. v230 is the latest version for that model.
                            • PrintWolf
                              • Jan 2025
                              • 2
                              Hello invalid_pointer can you please upload the firmware again? The link is expired, it would be very helpful for me, thank you!
