2551ci - Error C4600
  • Nanorizzi
    • Feb 2021
    • 4
    285 / 5000
    Risultati della traduzione
    Hello everyone,sorry for my bad english but i'm an italian guy who writes from florence.A friend gave me a working Kyocera 2551ci as a gift.I took it to my office and when I turned it on, the C4600 error appeared on the display.What can I do to fix it?
  • copiertec
    • Jan 2016
    • 2184
    Re: 2551ci - Error C4600
    C4600 Taskalfa 2551ci & 3551ci
    • Nanorizzi
      • Feb 2021
      • 4
      Thanks for the reply.
      I am not a technician and in the indicated post I cannot understand what I should do, could you please help me
        C4600 is a laser cleaning error. Most likely the cleaning system is binding. Probably not something an end-user wants to tackle, in my humble opinion. Maybe try calling a service tech?
        • Nanorizzi
          • Feb 2021
          • 4
          you would like to say that it is not a solvable problem by "pressing" something but it is a mechanical problem?
            Yes, most likely it's a mechanical problem.
            • Nanorizzi
              • Feb 2021
              • 4
              Thanks for everything, very kind
              • copiertec
                • Jan 2016
                • 2184
                You need to remove the laser unit and lube the cleaners. Sounds like you need a local copier company to come fix it.
