Sending from Yahoo address on Kyocera
  • kuby
    • Oct 2007
    • 1405
    Is it possible to setup a Kyocera to send thru a Yahoo address anymore. Or did Yahoo kill that with their new security and new authentication setting?
  • kuby
    • Oct 2007
    • 1405
    Re: Sending from Yahoo address on Kyocera
    Yes it is possible..
    Set setting
    Go to Device setting: Go down to Network Setting.
    Turn Network SMTP: ON
    SMTP poet number: 465
    SMTP server name: smtp.mail.yahoo.com
    SMTP server timeout: 180
    SMTP authentication protocol: ON
    SMTP authenticate as: Other
    SMTP login user name: youremail@yahoo.com
    SMTP login password: Ok here you need to login your yahoo account and go to Account Info / Account Security and down on the bottom is a Manage Apps Passwords. You need to set up a app (other) and name it Kyocera and then Generate the password. This is the password you enter here.
    SMTP security: SSL/TLS
    • kuby
      • Oct 2007
      • 1405
      Just to let your know that all Yahoo accounts do not seem to work with these setting?
      Found a Yahoo address that does not work this way? Have to try different setting to try and get it to work. Have set the App password but it will not send?
