kyocera 6500i after u002 factory default result dark bad copies
  • batabusiness
    • Sep 2015
    • 12
    kyocera 6500i made f000 error code, i went to maintenace mode ,then U002 factory default,resart the machine got normal ready, but the became very dark,and dark backgound ,so how to set the good copy quality again
  • kuby
    • Oct 2007
    • 1408
    Re: kyocera 6500i after u002 factory default result dark bad copies
    Did you make a backup of the setting before you set everything back to factory? I believe that you needed to run U917 and backup the data to a flash drive if not mistaken before running U002 from what I have read.
