Kyocera M3655idn waste toner door opens
  • RandyW
    • Jan 2013
    • 206
    have an account that says their waste toner cover pops open and they have to hold it close.
    Is this an actual thing with that machine? Looks kind of like some of the previous models I think M3540 types.
    1 of our techs is looking at and says the door seems fine. Did have some toner on the waste toner bottle neck. Took awhile to reset the replace waste toner
    box message when it was removed from the machine.
    Not sure how many pages are on it.
  • kjg
    • Mar 2009
    • 111
    Re: Kyocera M3655idn waste toner door opens
    It wouldn't happen to set where direct sunlight hits it at some point in the day would it? I installed one that wouldn't function at all until I moved it out of the light. I tested it to confirm it was sunlight striking the left side causing the error. If that is the case, try turning it 90 degrees where it sits and see if the problem goes away. if so, it may need to be relocated.
    • sparkycivic
      • Apr 2017
      • 348
      In those cases, we also had good results using black marker to color the inside areas of the door near the waste bottle sensor to absorb maximum sunlight that bounces around after entering from the vents.
