*** Thanks. With MyQ (same that KNManager) was solved the problem. It have watermark and timestamp is one option!. (important configure kyocera printer driver to PCLXL!!!)
Is a expensive solution... but is a solution!!!
I'm glad you found a solution. Thank you for the follow-up/solution reply, as many posts are missing this part.
