Kyocera 3252ci
  • rjohnson843
    • 7
    Kyocera 3252ci
    Hi guys I have a Kyocera 3252ci with 706k on it. Im getting constant c7901 C7902 c7903 c7904 C7620 c7614 in no particular order. I have updated firmware replaced the transfer belt and inspected the drum and developer units. Has anyone seen something similar or have any idea what may be causing this
  • Tech09
    • Apr 2020
    • 147
    Have you reseated connectors on the Drum/Dev Relay Board? Try that then you may want to try replacing it, PWB Drum DLP Connect Assy 302L794030.
    • kuby
      • Oct 2007
      • 1411
      Had one throwing a lot of C7620 codes and others related and could not figure it out. Took it to the shop and found that the DR-8350 (302L793120) was bad and had a bad cleaning motor gear and 40/21 tooth gear that drives it and both had some worn teeth. You have to replace the whole assy. per Kyocera but did some research and found the parts . Kyocera told me they do not sell just the parts for the assy. But I found them.
      Take the back cover off and see if it makes a noise or popping when you start it up. Mine would make it on start up. Look at the drive assy and the gear. Worth looking at.
      wormwheel drive gear - 302K021480
      parts DC motor assy - 302ND94050 (different color gear but it worked)
      Replaced these parts and has been working for over 3 months and no problems.
      • outdoorkatie123
        • Feb 2017
        • 50
        Hi had this problem a few times and replacing feed image pwb sorted it for me
