Kyocera Printing System 17 code 1030
  • nathicana
    • Aug 2008
    • 335
    4054ci with Fiery printing system has 1030 code that comes back within a few minutes of power on. Control panel says check connection to printing system. The Fiery icon appears on the home screen of the 4054ci but nothing shows when selecting the icon.
    Going by the installation guide I checked the connections between the Fiery and the interface board on the 4054ci, reseated the connectors. There are service switches on the Fiery that seemed to be in the wrong position. I set them both to off which the PS-17 service guide indicates is the normal position, no change. I'm considering reloading the system software which Kyocera says is the next step. They recommend leaving ipv6 enabled on the 4054ci, it was already enabled. Has anyone had experience with this problem?
  • nathicana
    • Aug 2008
    • 335
    I loaded the system software and the Fiery is now working. I used the USB removable drive method.
    In case anyone has the same problem I had:
    The USB drive is made using the Fiery Installer Builder. See the Printing System 17 service guide, it describes where to get the Fiery Installer Builder, how to make the USB stick and then load the system software on the Fiery.
    • justanotherhack
      • Apr 2015
      • 74
      We have a pretty high failure rate on fierys right out of the box. Usually reloading the software as you did fixes it.
