My MFP Taskalfa 3051 Taking a shower and the result is awesome ( Remanfacturing )
  • Mostafa Mostafa
    • 27
    Actually it's so fun to post in worldwide Copytechnet for MFP :
    I Used to take care of my machines away from dust, lousy noise, and slow act. so I keep up with specific details such as using Iso Propyl Alchol & Silicon Oil to clean fuser, Change Drum Blades, even fixed one with just a designed one and flexible parts homemade, clean Developer with full washed under water with liquid soap etc.. then reattach each parts same as manfacture.
    In conclusion I took my machine for a heavy shower in a long bath and used my Air blower to dry each part after complete dismantle it and I mean it completely dismantle it into parts , of manfacturing of course it's not solar Cell to keep it secretly in mafacturing but mostly untie everything It disolving it into parts and reattach each parts after washd it and make sure it's completely dry and clean .
    The result is amazing . Keep up the good work Kyocera I don't need any consumable parts anymore I even clear logs, reset EBROMS (DRUM PWB ,DEVELOPER PWB , ENGINE PWB, CONTROL PWB ) Laser Unit , Developer Units , Drum Units , Primary Transfer Belt, Secondary Transfr Belt etc... so my machine keeps new.
    Thanks for the good work in Module XX51Ci amazing just need to get full DRUM Motors and I will try to get them to upgrade my machines into 6551CI instead of 3051CI.
  • Mostafa Mostafa
    • 27
    If there is a new firmware newer than 2N4_2000.007.451 2020.3.17 I would love to get it I could not reach KD Server to get it for free and I don't have the permissions to do so, glad to get help. thanks in advance guys.
    • vernakuhlman
      • Mar 2024
      • 8
      Very impressive! I admire your meticulous Kyocera MFP maintenance. Cleaning with Iso Propyl Alcohol and Silicon Oil, manufacturing your own parts, and giving the machine a 'hard shower' can increase its longevity. Resetting the EBROMS and slope upgrading to the 6551CI variant intrigues me. Have these changes improved performance or print quality?
      • Mostafa Mostafa
        • 27
        Smooth Operation , Zero Error at all and enhanced quality in each aspect, that's what I got.
