maintenance kit reset Kyocera P2135
  • 1stcavvet
    • Apr 2015
    • 231
    What am I missing here I even looked in the manual---what resets the --Replace the mk message----- is the drum or the dv unit reset itself. Can't find any procedure in the manual. maybe it's saying the waste container is full? ANYONE KNOW ???? Thanks
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: maintenance kit reset Kyocera P2135
    A few tricky Kyocera models that I know of
    1) The reset option is in the system menu-adjust-service but won't appear there until the cycle is due.
    2)You need a brand new drum. Even if you replaced one last week for a scratch if it won't reset until it's looking for one. (has to be new, machine has to be turned off, install, turn on.)
    3)Try running a "Set developer" to clear it.
    • GeneOR95
      • Feb 2018
      • 161
      Page 1-3-8 of the service manual
      Procedure
      1. Enter the maintenance mode [>>Maintenance].
      2. Press the OK key. [>>Maintenance?] will be displayed.
      3. Press the OK key twice. The counter for each component is reset immediately.
      Completion
      Note:
      Occurrences of resetting the maintenance kits are recorded on the service status page or
      event log in number of pages at which the maintenance kit was replaced (See page 1-3-2, 1-3-
      10). This may be used to determine the possibility that the counter was errorneously or unintentionally
      reset.
