Close Bridge Unit door message
  • dantab1980
    DanTab
    • May 2015
    • 14
    [Error Code] Close Bridge Unit door message
    Working on a Kyocera Taskalfa 5052ci with inner finisher and it displayed a "close bridge unit door" message despite not having one. Replaced the Feed image PWB and that resolved the issue.
  • craigster
    • Apr 2016
    • 201
    Re: Close Bridge Unit door message
    Wow! That was a weird one!! Thanks for the share
    • Konicatech
      • Feb 2016
      • 131
      Where the inner finisher connects to the machine, put some washers under the connector to space the connector out and make a tighter fit against the machine.
      I have had all sorts of issues with the inner finishers and its mostly been caused by the connector not making a good enough connection
      • fishleg
        • Mar 2009
        • 426
        8800 error / tray full all the time. I can't believe they haven't fixed it already with a better finisher it's because the finisher part of connector isn't supported at all. You can bend it with very little force.
