Taskalfa 3252ci drum counter reset
  • Konicatech
    • Feb 2016
    • 133
    Is it possible to reset the drum counter to 0 on these machines? For example you rebuild the drum unit with new OPC, blade, PCR etc and want to reset the counter?
    Or is there a chip available to reset these drums?
    • 16839
    Re: Taskalfa 3252ci drum counter reset
    I think the drum counter is controlled by an EPROM and I'm unaware of a replacement.
    • JR2ALTA
      • Feb 2010
      • 2032
      There won't be any "replace drum" message on the screen if that's what you're worried about.
      If drums are too expensive, just stock up on charge rollers. That's most of the quality issues. The drums last long time.
      • sparkycivic
        • Apr 2017
        • 347
        Minor quip: the drums on the 35-60 ppm devices last a long time.
        The 25-32 models have been wearing out their drum surface coating prematurely quite often in my fleet, resulting in background at the page top and bottom.
        • Konicatech
          • Feb 2016
          • 133
          Same here,
          Drums for this model are rather expensive when the machine is out of warranty period - I can get a drum rebuild kit but when you fit them you get black pages unless you turn off DC Bias auto adj. this is because the drum counter is not reset.
          • tsbservice
            Field tech
            • 8151
            • Konicatech
              • Feb 2016
              • 133
              Thanks, dont think the chip is available for this model
              • GeneOR95
                • Feb 2018
                • 161
                If you know how to send a prescribe command to the unit this command should do it.
                - Set printer drum PM count to zero (can set to any count).
                • Konicatech
                  • Feb 2016
                  • 133
                  Thanks for this, didn't know this was possible! Have you done it on the Taskalfa 3252ci series?
                  • GeneOR95
                    • Feb 2018
                    • 161
                    To be honest I don't recall if I have or not. I can not test is either as I have no access to equipment since my company "downsized" due to covid over a year ago.
                    • jakeofall
                      • Aug 2017
                      • 1
                      Please send more info about this. Thanks
                      or where can I get the reference?
                      • Konicatech
                        • Feb 2016
                        • 133
                        It cannot be done for this machine
                        • copytech,mike
                          CopyTech,MIKE
                          • Jun 2014
                          • 261
                          Frustration machine for sure!
