TASKalfa 508ci - toner supply replacement
  • kuby
    • Oct 2007
    • 1411
    Does anyone had the procedures for replacing the toner supply assembly on a TA 508ci. I have the one for the 406ci but I think the 508ci is different. I looked on Kyocera web site and did not see anything on how to do this.
  • Luther
    • May 2006
    • 682
    Re: TASKalfa 508ci - toner supply replacement
    It's in the service manual beginning on page 4-4
    • kuby
      • Oct 2007
      • 1411
      Sorry but the procedures for replacing the TONER SUPPLY ASSY SP are not in the manual. 302WH94070
      • nathicana
        • Aug 2008
        • 335
        Is this what you're looking for?
        Toner Supply Drive Unit.pdf
        • kuby
          • Oct 2007
          • 1411
          I contacted Kyocera and they send me the right diagram to follow. It is not in the manual.
          • toddanderson
            • Dec 2005
            • 238
            Can you post the file here
            • kuby
              • Oct 2007
              • 1411
              They use the 406ci procedure. They said the Procedure is similar? I guess you have to figure out the differences?
