Ducument feeder
  • GeorgeBest
    • Jul 2009
    • 526
    Ducument feeder
    HI,
    Got a problem on a document feeder (part broken) from a Kyocera 3252ci . .
    Does someone know if the document feeder from the 5052ci the same, compatable, is ?
    Not much experience on this model
    Thanks in advance
  • kuby
    • Oct 2007
    • 1407
    Depending on which document processor you are gong to use, the DP-7100 and DP-7110 will work on both models according to the spec sheet. But the DP-7120 only works on a 3252ci.
    • GeorgeBest
      • Jul 2009
      • 526
      Its an DP-7100, so tnx!
