TA-306/307ci scan to Google drive
  • copiertec
    • Jan 2016
    • 2206
    We have a client that wants to setup scanning though Google drive on a 306ci and a 307ci. Do we need a Hypas app for this? I'm not that familiar with Google drive.
  • green4go
    • Jan 2022
    • 51
    Re: TA-306/307ci scan to Google drive
    Kyocera has the Google connect hypas app. Or you can use PinpointScan to scan to the Goggle drive on you PC or Mac.
      • 30216
      • copiertec
        • Jan 2016
        • 2206
        Do you have a prefer one app over another for this instance? Their entire office is Mac.
        • green4go
          • Jan 2022
          • 51
          I have only installed on for Google Connect because it can be slow when you login at times. The PinPointScan works well with Macs or PCs.
          • copiertec
            • Jan 2016
            • 2206
            I have loaded the trial version of Google Connector to see if this will work for the client's needs. But, I have a problem when I enter their email address in the Google Connector app, I get this message, " This browser or app may not be secure. Try using a different browser to sign in." The Internet Browser app is turned on in the mfp and set to Google for the homepage and I am using the clients gmail to sign in. Am I missing something in order to get it to connect?
              • 30216
              Here you go
              Is firmware up to date?
              • copiertec
                • Jan 2016
                • 2206
                Thank you, BSM. Yes, the firmware is up to date for both, V1.02 for the 307ci and V.5.03 for the 306ci. So, do I need to use the Cloud Connector app in conjunction with Google connector in order for it to communicate?
                • green4go
                  • Jan 2022
                  • 51
                  The Google Connector that I install, I had to call Kyocera support. they gave me an eval firmware that allowed the connector to work. Sorry but I don't know where it is since that was the only one i installed.
                  • copiertec
                    • Jan 2016
                    • 2206
                    I was thinking i needed to head down this route, thanks grren4go, I will place a call with support.
