KFS Version 2.3.x will end support for TLS v1.0/v1.1
  • yakyitz
    • 245
    As per the latest Bulletin
    KFS Version 2.3.x will end support for TLS v1.0/v1.1 planned to release in July 2025. Devices MUST BE SET for TLS 1.2 and/or TLS 1.3 BEFORE July 2025. Devices not set to TLS v1.2 will drop offline, after the update in July, and you will not be able to use KFS to change settings or update firmware. You will need to visit each device on site to bring them back online.
    My question is, is there a way using KFS to do this globally? Or do we have to go to each customer (in KFS) and check each machine?
  • kuby
    • Oct 2007
    • 1407
    Log in to the machine through KFS. Go to TASKS, Device Setting, TLS Settings and edit and select the options you need.
    You have to do each machine.
    • kuby
      • Oct 2007
      • 1407
      Bullentin
      • progoffice
        • Nov 2008
        • 334
        You can also save a device setting configuration with these changes and push it to multiple machines at once via KFS. You have to first make and save a separate configuration for each corresponding model/model range. Then you can simply filter your machines by model, select and push the changes. This should save a lot of time.
