Error Code C5101 taskalfa 3212i
  • Franzm
    • Oct 2021
    • 2
    [Error Code] Error Code C5101 taskalfa 3212i
    Hi All,
    I have been trying to fix this code from nearly a week now. I've tried replacing the charger unit, high voltage pwb. Also, today I replaced the drum. However the code c5101 persists. I have cleared u930 while replacing the charger. Is there anything I'm missing out?
    Any help appreciated. Thanks!
  • Fabio-1
    • Mar 2022
    • 6
    Re: Error Code C5101 taskalfa 3212i
    The only things you could do is to upgrade the firmware. If it doesn't work i will check the main motor and the engine pwb.
    • Franzm
      • Oct 2021
      • 2
      Thanks for your Reply. Just to add, after changing the high voltage pwb, I was able to take a few copies until the code appeared again. The machine has run for over 400k copies.
      • Mr2crazed
        • Jun 2014
        • 35
        Were you able to find a resolution?
        • sparkycivic
          • Apr 2017
          • 348
          make sure that the ground path for the drum is good. also check the HV path between the board and the drum MC and look for dust, toner or signs of arcing to chassis or other conductors. I suppose the developer should also be checked for debris, arcing to drum or other HV leakage. I don't remember specifically, but if a wire is used for HV on this model, ensure that it's clean and separated from other wires and chassis to avoid arcing through the insulation.
          • JR2ALTA
            • Feb 2010
            • 2028
            Did the machine recognize the new drum? Check Unit History printout.
