Copystar toner
  • dinotech
    Copystar toner
    Is the toner for the Copystar CS-2050 the same as the Kyocera KM-2050?
    I have TK-411 for the KM-2050.
  • 10871087
    • Jan 2005
    • 1062
    Toner is the same but the cartridge is probably different. They look very similar but there are ususally small differences in the drive gear on the toner container. sometimes they will work in the other machines but the toner drive gear doesn't positively match up so you get intemittant add toner messages and blank copies down the edges. look at the toner cartridge drive gears and you should be able to figure it out.
    • dinotech
      Thanks. I did compare that not too long ago and they are the same on this model. The only reason I wanted to check is because they are almost always different. Square versus triangle drive. Thanks for your help.
      • 10871087
        • Jan 2005
        • 1062
        check the gears closely, I have seen the pins that stick out of the toner drive gears look identical but actually be offset by a slight amount
