I have a TA408ci which locked up with F010. Current firmware was reloaded. The machine worked fine for a week then locked up again with F053. The machine will not go into firmware update mode with the USB drive inserted. The only option left from the manual says to replace the main board.
Has anyone had experience with this issue please and did a main board or SSD fix the problem, or did another solution work?
Thanks for any input.
Phil
Phil
