5053ci with Black background
  • toddanderson
    • Dec 2005
    • 236
    I have a 5053ci with black background over the complete copy.
    Replace the Black drum, Developer, Transfer belt, main HVunit. replaced when machine was unplugged
    all counters are reset. If I turn off U100 A/C auto adjustment my copies are perfect.
    Turn u100 auto adjustment back on background again. It changed the DC bias should be around 350 changes black to 835 and causes the background. IMG_4474.JPGIMG_4476.JPG
  • pascalb.
    • Aug 2016
    • 47
    Re: 5053ci with Black background
    Hello,
    What are the values in SIM 110
    Do not lament,
    do not mock,
    do not hate,
    but understand.
    • toddanderson
      • Dec 2005
      • 236
      All the counters where reset , when units replaced with power cord unplugged from the wall.
      Originally posted by pascalb.
      Hello,
      • ntbann
        • Jan 2012
        • 628
        Did you do the maintenance procedure in 952? Also had one that I had to run AC calibration8 again.
        • avio2
          • Jul 2010
          • 150
          • pascalb.
            • Aug 2016
            • 47
            Attention Avio2
            Your picture matches the transfer contacts.
            the PWB and DV high tension drum is located under the drive assembly.
            Do not lament,
            do not mock,
            do not hate,
            but understand.
