Here's a Brainbuster fs-c2526mfp
  • kenoking
    • Jul 2022
    • 22
    FS-c2526mfp. Client reports after changing toner, the removable memory indication is stuck on the screen. No Memory sticks are installed. Dimm re seated. Any Thoughts?
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Here's a Brainbuster fs-c2526mfp
    I've had "add toner" messages that wouldn't clear because the back door was ajar so the machine never reset itself. Machine is only smart enough to display one message at a time.
      This probelm kicked my butt the first time I saw it. From my notes:
      Problem: Machine says add cyan toner and message wouldn't clear after installing new cyan toner crtg.
      Solution: Customer had opened side cover during add toner message and not shut it back fully thus machine couldn't clear add toner message and it should be noted that when this scenario happens the machine will not display that a cover is open.
      • kenoking
        • Jul 2022
        • 22
        Thanks for the reply. Customer is bringing into shop. Better he than the Beast. Would be funny if it were that simple. Again TXS
