fs-3140 continuous adding toner warning!
+ More Options
Posts
  • alpertevfik
    • Sep 2006
    • 38
    hello, after the new mk-350 replacement, after choosing "new developer", it keeps giving "add toner" warning. Has anyone encountered this issue?
  • allstar59
    • Oct 2012
    • 67
    Re: fs-3140 continuous adding toner warning!
    Did you use a new OEM toner? After it finished cycling is there toner on the mag roller? I'd put the old developer unit back in to see if the message goes away.
    • Luther
      • May 2006
      • 682
      did you run u130? when installing a new dv you need to run it
      • alpertevfik
        • Sep 2006
        • 38
        there is toner in the magnetic roller, no problem with loading. I emptied the tank and reinstalled it with the original toner. The result has not changed. I put back the old developer unit, the message did not change.
        • alpertevfik
          • Sep 2006
          • 38
          u130 kodu fs-3140 modelinde mevcut deฤŸildir.
          • alpertevfik
            • Sep 2006
            • 38
            After a long waiting period with the original toner, it was finally ready. thanks. The problem was in the toner.
            • JR2ALTA
              • Feb 2010
              • 2033
              The toner might have been fine. After selecting "New Developer" it can add toner for well over 10 minutes.
