Kyocera Ecosys M6630cidn
  • Khumz
    • Feb 2020
    • 63
    I have Ecosys M6630cidn. This machine does not power up. The moment i plug in power cable it flashes memory light three times and stops. Display is blank. Power supply is quite as well.
    Anyone came across this problem before?
    Khumz
  • copykat93
    • Oct 2021
    • 275
    Re: Kyocera Ecosys M6630cidn
    I haven't seen this issue with this model, but I would start by removing everything from the machine.
    Toners, transfer belt, drums & fuser & see if if goes any further when you plug in. I have seen weird problems start after changing a toner because of a bad chip... keep us posted please
    • copydocinc
      • Mar 2015
      • 263
      I am not reading where you actually turned on the machine. Push the power button, that is under the control panel.
      Khumz
