taskalfa 5501i
  • Gab
    • Aug 2015
    • 676
    taskalfa 5501i
    error 6250 appeared . I swaped the whole fusing unit with an other from an other machine with no result.
    I swapted poer supply from an other one 5501 with no result.
    I swaped main PWB with an other one fron other machine and now i have error 180.
    I think serial No doesn't much .
    Can i do something ?
    • 30430
    Re: taskalfa 5501i
    Did you do a reset?
    put back the original boards and do the reset
    • Gab
      • Aug 2015
      • 676
      Re: taskalfa 5501i
      Did you do a reset?
      Yes i did a reset (U906) befora i swap the boards.
      • CopyTech03
        • Jul 2020
        • 55
        Re: taskalfa 5501i
        Reinstall original boards to hopefully get rid of the 180 error. The c6250 is fuser drive, you will need to replace the fuser drive assembly.
        • sparkycivic
          • Apr 2017
          • 348
          Re: taskalfa 5501i
          reset for fuser errors needs u163
