Feed back on the Copystar CS-308Ci... is this a decent machine?
  • copykat93
    • Oct 2021
    • 276
    Hi guys, I have a customer that will do MAX of 15-20K per year for church bulletins and little jobs here & there. It will be a copier/printer only, no scanning ... so I just wanted some feedback on the unit & toner yields, if they're close to stated yields? Any issues with this model? Only 1 drawer & no other options added to it.
  • copykat93
    • Oct 2021
    • 276
    Re: Feed back on the Copystar CS-308Ci... is this a decent machine?
    Is there nothing good about these units, or doesn't anyone in here have any of the CS 308Ci out in the field? Kind of hard to believe that nobody has these units to give some feedback on them.
      • 30185
      They work fine for low volume
      All toner yields are based on a 5% fill
      No magic in that number more coverage lower yield
      • copykat93
        • Oct 2021
        • 276
        What do you consider "low volume"? should it be ok with 20K or less per year?
          • 30185
          Perfect it can do more than that
          • Submairnergold
            • Apr 2022
            • 3
            I have several of these plus the older version . Not many service calls on these guys as long as the customer doesn't abuse the doc feeder. Good machine for the size
            • fishleg
              • Mar 2009
              • 426
              Just remember think the mk is 200k on these drums don't usually last much longer than that.
              Only major issue we've had is toner pipe clogging on 2 which is a major strip down.... Doesn't happen often though.
              We have schools who have done 200k+ very little calls on them.
