taskalfa 5501i scaner
  • Gab
    • Aug 2015
    • 677
    Trying to enter command center to set up for scanning the following message
    error during connection to 192.168.1.15 . The Hub not supported version of safty protocol .
    The site you are trying to enter can not be shown because is not possible verifycation of the receipted data.
    This site may not support protocol TLS 1.2 which is the last version supported by firefox.
    (The above messages are a translation from my language)
    Also s/w version 2N9-2000.006.o51
    Any idea how to set up copier for scanning?
    • 30552
    Re: taskalfa 5501i scaner
    Try different browsers or you can kmnet viewer to add addresses
    You can also use the panel
    • sparkycivic
      • Apr 2017
      • 348
      This has been solved in a previous post regarding TLS in web browsers.
      You need to find the setting inside your web browser to allow connections to websites offering the older version.
      Here it ishttps://www.copytechnet.com/forums/k...t=#post2135227
