kyocera KM 1815LA codigo c6020
  • javier4065
    • Feb 2007
    • 251
    hello friends,I hace a problem with this copier, I can't clear it.I wil be glad if some body can help me thanks.
  • dbrownlee
    • Sep 2005
    • 198
    Fuser section overheated. Check THMS, if 0 ohms, replace, otherwise power supply board. Reset code is U163 after repaired.
    GO TIGERS!!
    • javier4065
      • Feb 2007
      • 251
      How do I enter service mode for kyocera 1815LA
      thanks for your answer DBROWNLEE, I need to know,how do I enter service mode, I don't speak english very well, sorry if I 'm not writing rigth
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        First open top cover then turn on power.
        press system menu/counter
        arrow down to service
        press and hold start, # then enter keys
        arrow down to maintenance
        press enter
        arrow down to Sim 163
        press enter
        select execute
        press enter
        turn off power then back on
        Hope this helps you
        My mission here on Earth is to help all you Dum-Dums!
