M6630cidn cannot connect to smtp
  • taskalfa
    • Jun 2011
    • 97
    [Error Code] M6630cidn cannot connect to smtp
    Hi techs, just seeing if anyone has had similar issues with this model, simply cannot get the printer to connect to smtp , user has other kyocera products like the p2040dn and m5526cdn which all work fine with smtp settings.
  • copiertec
    • Jan 2016
    • 2211
    Re: M6630cidn cannot connect to smtp
    What smtp server are you trying to connect to? What dns server are you using? What port are you using? Is all your TLS 1.2 ports active? Is you firmware up to date? We have not had any issues with this model connecting to smtp servers. Your not giving us much to work with here.
    • taskalfa
      • Jun 2011
      • 97
      sorry
      smtp server name : smtp-mail.outlook.com
      port : 587
      smtp security: starttls
      Authentication: user name and password
      dNS primary 192.168.1.1
      secondary 8.8.8.8
      TLS 1.2 active
      like I mentioned all other models seem to work just fine with the same settings
      • copiertec
        • Jan 2016
        • 2211
        What error are you receiving? When you test your settings on the smtp page does it come back complete or does it error out? What sender address are you using because if the sender address are you using at the bottom of the smtp page? Because if it not a working email it will not work, for example, scans@yourbusiness.com, if it's not a real email it will error out with an smtp error because it is not a recognized email.
        • taskalfa
          • Jun 2011
          • 97
            • 30544
            sender and user name the same?
            • richs
              • Nov 2008
              • 266
              I have never had a machine cause an email problem because something in it wasnt working.It has always been wrong info or something on the network not working or blocking the email.A few times I have had to take a working machine to the customers just to prove it was their info or network.
              • taskalfa
                • Jun 2011
                • 97
                Factory reset did the trick
