km4850w
  • ling
    • Jul 2025
    km4850w
    Hello ! I need some help , can anyone shared detailed how to setup printer driver in pc to link with km4850w. thanks. Greatly appreaciated.
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    If you have the CD you first need to install the KM-Wide TCP ip port which installs a Wide TCP ip port. Then you can install the driver choosing the TCP ip Wide port. After installing the driver you can proceed to installing the KM-Wide print utility.
    My mission here on Earth is to help all you Dum-Dums!
    • ling
