memory overflow of KM-1500
  • jewen25
    • Mar 2009
    • 194
    its main pwb error? how to fix?
    ERROR HELP ME AND HELP YOU
  • HPLEXKYOPT
    • May 2009
    • 18
    The memory over flow message can come up when the wrong paper size is sent to the machine, or if a paper type with paper not available is sent.
    The other possabilities if you went by the book, whatever you send has used all the machines memory, so add more memory.
    But in my experience, your best bet would be it's a corrupt print job.
    • jaime
      • 16
      single press of this key rate to one side has the figure of an enter key, the memory is empty and you can continue copying
      • jewen25
        • Mar 2009
        • 194
        what key? to press?
