Taskalpha 3252 Changing Subject line in scans from copier
  • Doug James
    • Jan 2012
    • 935
    [Misc] Taskalpha 3252 Changing Subject line in scans from copier
    When we scan it shows
    Company Name @ Gmail.com as the sender
    Also The memo or subject line shows
    Scans from TASKalfa 3252ci
    needing to know if it is possible to rename this - indicating that it is a scan from the company.
    Thanks so much for any help with this !!
  • darry1322
    • Oct 2010
    • 817
    Re: Taskalpha 3252 Changing Subject line in scans from copier
    In Command Center go into Function Settings -> Common/Job Default Settings and you will find the setting for Subject Line
    • Doug James
      • Jan 2012
      • 935
      Thanks so much !!
