Kyocera Printer Maintenance Message
  • i-have-fax-problems
    • Mar 2020
    • 109
    Hello,
    is there a possibility to reset the display message without that the printer will do
    a installation routine. I know when I press "new drum" in the menu the printer resets it but makes
    a installing routine. Drum is quite new but not so new so I fear I will have problems with stripes afterward.
    I've already made this experience.
  • copiertec
    • Jan 2016
    • 2223
    Re: Kyocera Printer Maintenance Message
    Is it a printer or a copier? I know in the copiers you can extend messages of life counts but not sure about the printers.
      • Mar 2020
      • 109
      Sorry I've forgot to say it's a P3155.
      • copiertec
        • Jan 2016
        • 2223
        I believe your only option is though the control panel and reset maintenance kit/ drum count, etc.
