I have a problem with my ecosys M5521cdn.
When i print a document with text and images from pc or usb the background's color of image is gray instead of white.
If i try to copy and print the same image from the scanner, the background is ok.
If I print a document with only text, the print is perfect.
I used without problems the printer for 3 years (3500 copies)
I tried to clean the drum and DEV, but the result is the same...
Could you help me?
Thank you
Could you help me?
Thank you
