Olivetti PGL2550/Kyocera Ecosys P3050dn - Toner Emtpy Message
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 62
    Hi there!
    A few weeks ago we've replaced the Maintenance Kit (Deve, Drum, Fuser, Roller, etc) on an Olivetti PGL2550 (Kyocera Eco P3050dn same modell/parts)
    Everything prints fine but after a few pages the machine sends out "Toner Empty", when you take out the Toner and shake it, it works fine again.
    Toner has been replaced already, but the problem persists.
    Perhaps does someone know what could be the culprit for that message?
    Thanks in advance !
  • B0265
    • Jan 2007
    • 718
    Re: Olivetti PGL2550/Kyocera Ecosys P3050dn - Toner Emtpy Message
    Did you remember to run "new developer" in service mode?
    • CroceL
      • Jun 2020
      • 62
      Yeah did that, filled up the DV unit.
      Everything prints fine and looks good, apart from the error that occurs multiple times a day.
      • diedux
        • Jan 2017
        • 124
        Are you sure your drum unit matches the pattern on the toner cartridge? If not, the toner is not properly delivered to DV.
        Seen this a few times when utax-triumph/olivetti/kyocera parts were shuffled around. Easy solvable if you have an old/original drum unit.
        • subaro
          • Oct 2010
          • 1274
          Make sure the toner container lever on the left hand side works properly. Push down on the top of the container and then push the blue lever . It should move smoothly. If not replace the toner. That lever opens the toner supply door to fill the dev unit.
          • CroceL
            • Jun 2020
            • 62
            [ATTACH=CONFIG]62301[/ATTACH]
            That was it, thanks alot guys ! Maintenance Kit apparently had a Kyo Drum...
            I will burn all Kyo/Oli Printers in the future !
            • subaro
              • Oct 2010
              • 1274
              Nice that your problem is solved and thanks for the feedback. Many people get help here and never bother to post their result, which does not encourage others to post.
              So, problem solvers, post your fix, when it is solved.
              We have lots of those small kyocera in cement plants and production sites. They get filled with dust and still work fine. I sometime wonder how the sensors on the machines withstand all that dust and still function.
