6030/8030 LDAP help
  • oxtails
    • Jun 2009
    • 14
    6030/8030 LDAP help
    please could anyone tell me how to (if poss) set up ldap on 6030/8030. i have enabled ldap within service mode but am completely lost from there onwards and cannot find any info whatsoever.
    thanks in advance
    • 29378
    download LDAP scanner software
    Kyocera LDAP Converter Ver. 2.5.0
    Kyocera Light Directory Access Protocol (LDAP) Converter utility used for connecting "in-house" e-mail servers to select an e-mail destination when scanning to e-mail using Kyocera Mita Scanning System. This version will run in Service Mode.
    • trinikyotech
      first you have to enable ldap service as you already did, second you have to load the software on the server and the machine should be able to pull the info
      • oxtails
        • Jun 2009
        • 14
        Great!!!! But.......
        thanks for the info on the ldap converter. i have now downloaded the software but could i just double check
        1) host address is the email server??
        2) where does the software find the ip address of the MFP?
        3) is there a setup guide??? could someone "talk" me through the info needed to get this to work?
        sorry for so many questions but this is the first time i've seen this software and any help would be much appriciated
        • Frits
          • Jun 2009
          • 62
          The software must be on the same server as your printer
          1) Hostname is server name
          2) username and password from the server
          3) Searchbase dc=servername, dc=local
          4) Start the software
