New 3050 doesn't work after installation. In the warming up shows "unknown toner" then writes "ready to copy", when start key is pressed paper is picked up and then stops near registration and code 7910 is shown. changing toner, developer unit didn't help. changing firmware to the 2.40 and down to 2.05 (between them kyocera changed some data about "unknown toner") didn't give any result.
code C7910 KM-3050
Developing unit EEPROM errorReading from or writing to EEPROMReplace the developing unit.
cannot be performed.
Poor contact in the
connector terminals.
Check the connection of connector on the
engine PWB and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective developing
unit.
